slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
That's what I am testing here. Before I had this on there I had Hot Racing chassis braces and a tower to tower brace, even with those I could easily flex the chassis front to back, with the Alza Racing top plate there is zero flex back to front, but I do have a very slight bit of twist side to side, I never checked if the Hot Racing and t2t setup had any twist to it though.Would that upper brace be better than aluminum chassis brace and a t2t
But I bashed it hard yesterday, almost punched a hole in my Unbreakable body and so far no issues.
I still suspect that the rear brace not being there will be an issue with the lwb chassis however. So if you have a Kraton your results will probably be different from mine.
