Anyone know what would cause this?
Steering won’t return to (0)
Don’t mind me I’m a noob, what is the servo saverServo not strong enough to recenter
Servo saver too loose
A combination of both
this could be it had a rough front end collision.. bent dogbone, bent front shock tower, fixed the first 2. Slightly bent chassis up. Now I just looked closely at the servo and noticed gear wiggle with barely any tension on the rack.. think my servo is fiddlesticked. Anyone got a extra chassis they wanna sell? And new servo? Maybe an upgraded servo any suggestions?Have seen bellcrank Ackerman bent as well.
Also I’m on RWD only now .. when I turn bolts my front wheels the center diff does not turn motor... suspecting broken center diffDon’t mind me I’m a noob, what is the servo saver
This is the servo saver, and that black spiked nut should be 5 to 7 mm off the chassis. Good YouTube videos on how to adjust on the Arrma TV part of their website. Motor won't turn when you spin the fronts alone. All four wheels at the same time. Put it on the ground and push it. That heavy clacking metal sound is the magnets in the motor while the rotor is turning inside. Stock replacement parts are very cheap from kit breakers like https://jennysrc.com/search?type=product&q=Arrma. Good luck and don't stop trying til you get it right.Don’t mind me I’m a noob, what is the servo saver
