Dolarin
- Points
- 68
- Typhon Mega
Greetings,
I'm in the process of reassembling my Typhon. One of the many issues it had when I bought it was a broken rear input gear. I bought a new one, put the bearings on it, and installed everything back the way it was. But when I tested it out by hand I noted that it was pretty "chunky" when I turned the input gear. I verified I have the right tooth count, and the mesh seems fine. I did notice that if I backed the two screws that hold the case together off a little bit it got a lot easier to turn. I am assuming what's happening is the case is putting to much pressure on something. Anyone had any experience with this before? I appreciate the help.
