SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
That little "plastic clip spacer" as you refer to is the "Pill Mount" Holding the H. Pins. I would look into your TLRT manual better to understand what they actually do. You MUST replace that if it is damaged or cracked. The included bag of inserts has all different styles in "Pairs" for L-and R hand sides. I found myself having to buy them, when I am short of a matched set. And the actual Pill you use must Be a match to the other side exactly. No way a round this. Or your suspension alignment will be all Jacked up !! You cant just randomly install a another. Need to refer to the TLRT Pill Chart in the manual specifically.
I have even had mine fly off, a goner, with Hinge Pins bent up and all.
