chilly81
- Fireteam
- Granite
- Typhon 3s
I just rebuilt and evaluated a few different shocks for a Frankenstein build. I’m doing. One of them was the TLR typhon shocks which I was always curious about how legit they were. So I figured I’d post what I saw.
Basically, they are the same, except for the piston has a nicer shape to it, and the O-rings are a little X cross-section type rings with a slightly different spacer holding them in. Everything else is the same. It’s just different colors. They are also longer than the commonly used Kraton 6S upgrade.
The tlr pics are the first ones with the white oring. I also had a set of Kyosho MP 10 shocks as an option. And although the TLR shocks seem really good and even the base 6s ones are quite good, the Kyosho ones are definitely a step up in all regards. But I’m gonna stick with the TLR ones because they fit with my build theme better. I was going to try to cannibalize the caps and collars from those, but they are different thread sizes.
Kyosho
Kyosho
