- Notorious
- Talion
- Typhon 6s
One of my best off road spots for bashing my Typhon has become unreliable. My other spots are decent, but small for something so balistic fast. More ground clearance would give me at least 3-4 new good spots to bash off road, so I want to give that a shot.
What I have in mind is a Kratonish MT style rig. Looking for a size somewhere between the Talion & Kraton. I already have the Kraton hexes/hubs/axles, so thats less parts to buy. I want to run the Proline 3.8 LP Trenchers which are 5.6" od & 2.96 width and the Backflip LP's ( 6.1" od & 3" width) as my go to tires vs. the stock Kraton tires that are 6.8" od & 3" width. I'd like the Kraton length with just a little less width, so I'm thinking of the following:
- Kraton/Talion chassis (M2C or JBI unless there's a cheaper option thats good, lol)
- Mojave or Talion towers/shocks, could run my Typhon rear shocks up front and just need 2 new rear shocks
- Mojave arms, camber/toe links, front/rear driveshafts, front center driveshaft, front center brace
- Already have the Kraton hexes/hubs/axles
I also have been kicking around the idea of an XL Typhon or a similar setup to the Fireteam without the FT body. The Losi 3XL or HPI Savage XL 79 F150 body would fit the Mojave/Fireteam length chassis. Would be like the above build but with the Mojave/Fireteam chassis.
Just wondering if I'm going this far should I just go all the way and get the Kraton arms/driveshafts/etc? I'm want it to sit a bit higher than the Typhon without being as tall as the stock Kraton. Was thinking the Mojave arm width with Kraton hex/hub/axle would be a better choice for retaining a little sharper turning if I'll be running the LP versions of the Trenchers and Backflips. Any input or comment is appreciated.
