actually the old one its not responding as it should, that’s the reason i bought a new one and instead of buying same model i upgraded to a bit stronger oneWhat is your exact problem you are having with the new servo?
if it’s plug n play, then it might be the ESC is the problem?Servo is plug and play, doesn’t hurt to check end points however. Sounds like it wasn’t really an “upgrade” after all.
+1 also make sure your wiring polarity is correct.Yes a new servo is plug and play, except for setting again the end points.
Correct! Otherwise the servo doesn't work.+1 also make sure your wiring polarity is correct.
my old servo, throttle still working and only the steering that doesn’t work..but with this new servo..neither of the two worksYour receiver might be bad. When the receiver goes sometimes channels don’t work, or they exhibit some other undesirable behavior. Got another rig you could try out the servo in? Does the throttle work? Try swapping them around, steering into channel 2 and esc into channel 1, this is assuming throttle works currently. You could test out the steering when plugged into channel two with the throttle on the remote and the esc on the steering.
