Senton Upgrading my pinion motor gear
Senton
  1. 4x4-Mega
  2. Senton 6s
What's the biggest size pinion gear I can put in a senton 4x4 mega with the pre drilled mesh holes?
27t
What motor are you running?
I have a 4X4 Mega Granite and just slotted the holes playing connect the dots with a dremel. Now can run any pinion I want.
I would not go any higher than stock gearing with a brushed motor. To open up your gearing options you have to slot the holes but I doubt your motor will last very long going with higher gearing.
