leddmirage
- Talion
hi guys/gals,
i'm new to the hobby..just got myself a kraton v4..did some research before getting it..haven't run it yet..i am still noob..need some help..
1. do i need to shim the diff on the new v4?
2. i got 1 one those 3in1 hobbywing multifuntion LCD..can this be use to program the stock esc?
3. can automotive greaw be use on the outside diff gear? or require model grease? i think center diff cant be greased as its exposed below?
4. if i run on grass n compact sand..can i use the 16t pinion? its kinda warm/hot where i live..
5. would it help to install a fan to thr motor? what is the recommendation?
thanks in advance
thanks in advance
