Senton How to install Hot Racing steering arm?
Brewcity414
King of questions
Wisconsin
Hey I'd it any videos out there with instructions on how to install this part? I think I can eye ball it but I'd rather have a video as well
Remove the screws that attaches the servo saver/horn to the steering rod (access from underneath the truck.
Remove the screws that attaches the turnbuckles to the existing steering bellcrank.
Remove the side mud guards (at least I did for the Granite.)
Remove the 4 long screws from the underneath of the truck that hold the front diff housing together. Arrma has a video on how to do this.
Rock/tilt the front diff housing forward and remove the existing steering bellcrank.
Reverse the above to install. I think I got everything. I'm doing it from memory and I don't have a truck in front of me. It's a pretty easy swap.
Thanks
I started knocking my shocks loose whenever I access my diffs, and while I can't prove it, it seems like my shocks are lasting a bit longer before needing a rebuild. I'm thinking the bending pressure when you open up the diff housing is causing premature leaking, and it only takes a second to pull 2 more screws.
Definitely not a bad idea.
