Granite When should I inspect my diffs?
^^^ I mixed 500k with 1 mil. (y)(y)
Yeah, I never seen 700k myself.
Mixing is ok.
But it is a rough approximation, that can work.
I could have went straight from 500k to 1 Mil. A big jump ...
But I don't like to overshoot diff Oil cst.
I work my way up a little at a time., evaluate from there.
think I will try that (y)
There was a chart somewhere how to mix ratios to get close. It is done by using a scale. Kind of hard actually to be precise enough. Close enough is ok, and testing the rotating feel is how I judge best.
With mine, I just filled up the diff cup halfway with 500k and then added a "scoop" of 1 mil. My rough guess is 700k right now. Give or take obviously.
But it's somewhere in between 1 mil and 500k FWIW.
I use a shock vaccum pump to bleed out any air. Thicker oil takes much time to bleed out. Air left remaining ( Bubbles) inside means less oil is in there. Let bleed by sitting for an hour, then top off till full.
