Talion Why is this car constantly popping wheelie?
Niz55
I have a basically new talion exb with tons of aluminum upgrades, hubs, diff housing and more. Since day one I cannot get this car to go straight without doing a wheelie. I was running the stock pinion 16T with stock electronics.
Switch to castle MMX8S with 1650kv motor using same pinion 16T and still the fu cker wheelies.
Okay switched the crappy wheels and tires with outcast 4S and it got even worst.
Not sure what else I can do. I have been doing this rc car for 20 years (mostly 1/5 scales gas)and this little car is pissing me off really bad.
I mean should I install a 8T pinion?
I am getting ready to sell it for dirt cheap if I can't fix this problem.
Rob66
Potsdam, New York
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Mojave
  5. Mojave EXB
  6. Senton 3s
  7. Talion
  8. Typhon 3s
Maybe try really thin center diff oil?
Also could be the LSD center diff locking prematurely?
Niz55
The diff fluids been replaced with same exact what it came with and everything was installed correctly.
Not sure, are all the exb talions constantly doing wheelies?
The Bean
Portland, OR
  1. Notorious
Bigger motor/lower pinion --> more torque --> wheelies.
You can lower the punch (throttle responsiveness), get a smaller motor (stock should be fine), smaller (lighter) wheels, bigger pinion and just be less aggressive (but that isn't fun 😁)
Niz55
I have tried the stock setup first with the 16T and still did it. What pinion do you recommend with the my setup?
21STalion
  1. Talion
I've tried 15t, 18t, 20t and 23t on the 1717
23t is my favorite....
I will be a 23t/44t for regular offroad wheels and 30t/44t with hoons for the street this weekend if the weather holds
18t was really great but I wanted a tiny bit more
Moirae
Beauty & Beast
Colorado
  1. Felony
  2. Limitless
  3. Kraton 8S
  4. Kraton EXB
  5. Mojave EXB
  6. Notorious
  7. Talion
  8. Typhon 6s
  9. Typhon 3s
Lower punch. Backflip lp will also make you wheelie more than stock tires. What do you have punch control set to? With castle it's reversed. Higher the number the less punch you have.
Niz55
I have the 1520/1650 motor . I did try 20T and it was little better off start but once going no matter what speed I am in it will pop a wheelie on full throttle.
Punch is set to disable. If I lower it than I won't be able to control it in the air.
I don't know maybe I am just not used to 1/8 off road cars.
Moirae
Beauty & Beast
Colorado
  1. Felony
  2. Limitless
  3. Kraton 8S
  4. Kraton EXB
  5. Mojave EXB
  6. Notorious
  7. Talion
  8. Typhon 6s
  9. Typhon 3s
Nah bro you should easily be able to control it in the air. Especially with backflip tires. Your punch being disabled is 100% your problem. Try going to 50 or 40%. I have the same setup as you but I use 46 spur and like 28t pinion with punch set to 40 iirc
Talion double backflip with same electronics and backflip lp tires
Niz55
Ok I'll give that a try and turn down the punch but i am it sure if I want to run 28T might overheat the motor. I have a 20T I am going to try.
Moirae
Beauty & Beast
Colorado
  1. Felony
  2. Limitless
  3. Kraton 8S
  4. Kraton EXB
  5. Mojave EXB
  6. Notorious
  7. Talion
  8. Typhon 6s
  9. Typhon 3s
20t is a good start. Castle combo runs cool but I use 2 fans. Haha man I bet punch disabled was uncontrollable 🤣 you'll do so much better now. 👍
21STalion
  1. Talion
Oh I didn't notice you are running backflips?
And you are wondering why you are backfliping now? 🤣
But no really, it's the tires. Those are stunt tires, and should easily correct your flight mid air anytime
You can buy a wheelie bar and embrace it like @LicketySplit mentioned
Niz55
Well the stock tires did this as well but the stock wheels started to wobble the first jump and YouTube pointed me towards the backflips.
I really like this car and I want to keep it as I spent lots of money on it already.
Is this the correct one?
ARRMA AR320366 Wheelie Bar Set Outcast: ARAC9493,Black https://www.amazon.com/dp/B01NC24EDQ/ref=cm_sw_r_apan_i_N89XHR5XHR10T2ZAP21V
21STalion
  1. Talion
Yeah that wheelie will work I believe. Think about I have that one.
The Katars are great, but true, they don't have a lot of meat on them so they don't jump well, they can break.
The backflips with its thick chunky and stiff tread is good at jumping, durable, can take high speeds okay because are tough.
I never worry about wheelies with my low profile racing wheels....but they are all cracked on me as well
It's always a compromise with tires
Moirae
Beauty & Beast
Colorado
  1. Felony
  2. Limitless
  3. Kraton 8S
  4. Kraton EXB
  5. Mojave EXB
  6. Notorious
  7. Talion
  8. Typhon 6s
  9. Typhon 3s
Thats it, I also have it on my talion. Btw, I hope you have tire glue because those backflips will definitely come unglued at some point with that castle combo
Niz55
The stock tires were great. Never ballooned or anything but my god the wheels were junk. First jump 2 of the wheels started wobble by end of the pack all 4 wheels were wobbling pretty bad.
