PshmokN’EM887
I keep stripping the inside of my hoons rear ones here’s a pic someone help me I’m tired of changing new tires and also let me know if I can fix to re use the tires thanks
That sucks man. If it was mine I would make sure the wheel is on all the way. And maybe check bearings. Make sure nothing is binding up. My guess is probably is good as ursI keep stripping the inside of my hoons rear ones here’s a pic someone help me I’m tired of changing new tires and also let me know if I can fix to re use the tires thanks
Is tight you can see the mark from the nutA pic of the hub ? Try turning the hub with the tire off.
Connected like the nut tight and in all th way ?Check every hub when you put them on, if they aren’t aligned and connected, that can happen also make sure every wheel is tightened before each run.
Cool thanks man it makes sense yeah I have plenty I buy them from Jenny’s just to have I’ll swap it out before my next run !Corners are rounded it will continue at this point. I would replace them. Is your punch set high?
No I have it set at lowCorners are rounded it will continue at this point. I would replace them. Is your punch set high?
Yes I think it’s the hub it’s the second time that is has ate fairly new tire hubs it is I hope it stopsI would consider replacing that hub
Before you throw them out or whatever you are doing with them, check out this thread.Cool thanks man it makes sense yeah I have plenty I buy them from Jenny’s just to have I’ll swap it out before my next run !
I destroyed 4 sets of wheels by having the hex come loose and the hex on the wheel rounding off (2 of those times were with proline 8x32 replaceable hexes, so that was nice.)Yes I think it’s the hub it’s the second time that is has ate fairly new tire hubs it is I hope it stops
The hexes is where the tread is the locking nut goes on right ? Just to be clear what I’m replacing.I destroyed 4 sets of wheels by having the hex come loose and the hex on the wheel rounding off (2 of those times were with proline 8x32 replaceable hexes, so that was nice.)
edit: it was the same hub so I replaced the hub and hexes.
You are the fudging man my dude is the wide tires so more dough now I use the ones I have sitting there thanks you saved me money thanksBefore you throw them out or whatever you are doing with them, check out this thread.
Dude thanks I’m definitely doing this from now on thanks man !I've had wheels come off alot.sucks ruining new expensive wheels.. I guarantee you you do this and they'll never come off.had 1 come off in the 120s few weeks ago cause I forgot to put 1 back
on.hi -powered systems do it worse
You'll notice there's alot more resistance when taking them off for like 2 turns,opposed to 1/8 a turn from no orings..I've never had one come off with the orings..they act like a lock-washerYou are the fudging man my dude is the wide tires so more dough now I use the ones I have sitting there thanks you saved me money thanks
Bro!!!!!
https://jennysrc.com/collections/ar...ubs-red-limitless-typhon-senton-nuts-ar109001The hexes is where the tread is the locking nut goes on right ? Just to be clear what I’m replacing.
So don’t over tighten which I might do because I go even after is no more to go so you might have a point there .Is that the original Hoon.
I have never had this issue ever or loose or lost wheels while running these Hoons. I will say that with my Lim when new out the box, they were so tight that I had to destroy 3 of 4 to get them off. They were screwed on so tight at Factory Assy., that the wheel hubs were crushed and into the hubs. A few BB's were damaged a well. as were 2 front hex adapters and wheel nuts. HH stepped up no issue. My Lim was a very early release.
I can only say that your Hoon issues are user error. Once over tightened, ( point of no return) the wheel hexes are compromised. They crush. Spread out, round out and are useless. The nut will bottom out on the axle without much grip onto the wheel hex. Its just a domino etffect.
Again, I never had issues with my Hoons. The Disk (Lim) or Spoker versions. I check my nuts frequently before and between packs. Sometimes mid runs.
My spin.
Edit: not all upgrade closed wheel nuts are the same. Some are too deep some too shallow. and bottom out onto the hex adapter before they can truly snug against the wheel tight enough. Basically a loose wheel. The above o-ring trick can work I guess.
Yeah I have a few oh those sets that’s onto Jenny’s lol just for spare so I’m definitely swapping the tea ones out .https://jennysrc.com/collections/ar...ubs-red-limitless-typhon-senton-nuts-ar109001
that is the stuff that I would consider replacing.
Yeah as soon as I read your post I was like oh oh I over tighten like I said as a precaution when speed running but it never crossed my mind that it would cause wobble and bricks wheels thanks brother .At some point as you tighten the nuts, the serrations of the nut will bite the plastic(wheel). If you can feel that initial bite, just go 1/8 turn more.
It's just a feel that you develope. Repeating the same every time, every wheel the same way. Using the SAME wheel wrench. You end up with a feel for the torque that is needed. The wheels are rather soft plastic. Go Overtight one time or a few, and the wheel gets bricked. Becomes a problem wheel.
Tightening here is subjective. Can't explain it better.
