Jluther@becoinc
- Senton 6s
- Talion
I have a 6s Senton and tire options are very limited.
I might just order a set and see. I want something that will fit without cutting the body but look and grab better than the old stock or buggy tires.Almost exactly the same diameter as the Proline MX28 MT tires, which are listed at 128mm. If 2.8 tires fit on the Senton, the Mojave's should fit too.
I edited my reply. The Mojave tires are actually slightly shorter than MX 28s. Which is good, if you want them to fit without trimming the body.I might just order a set and see. I want something that will fit without cutting the body but look and grab better than the old stock or buggy tires.
