Notorious J
It's gonna break, so might as well send it!
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- On a midnight train to nowhere
- Gorgon
- Granite
- Notorious
- Typhon 6s
Tried to do some 8s hits today. Bogging was obvious because I'm running 35/36 in the center. With perfect pass, launch was okay but car got squirelly as it powered up. Took out the PP and now it's acting super strange. Even with really light pull, it cuts out completely. Managed to get a couple of times where it accelerated, but most of the time it just stopped. A full pull net no result at all. The motor is a 4070 2250kv and the timing is set at the default on the XLX2. The gearing is obviously an issue, but to have zero acceleration on 8s seems like there's a setting I missed. Is my gearing just to out there for this motor, or would a timing adjustment help. If you need to insult me because of that insane gear choice, please do. I knew it was a bad idea when I did it, but you know I'd do it anyways. If there's any recommendations on a pinion spur option that might be better, fire away, but no that the V2 motor mount doesn't allow for typical V1 mount gearing options ie: 27/34.
Edit: the motor is a regular TP
