- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
So since the launch of the Vendetta & limitless mega an the diff spur options started do some thinking on a 1/10 build.haven't purchased anything yet.still deciding on what system,setup to go with.so I'll want data logging an cc programming features. I also want to be able to fit combo down in chasssis.most 6s esc will only give ya 68ish mm of room so mmx6s an tp4030-3480kv is what ill start with.maybe go to mmx8s down the road.so after looking at the calculator looks like I'm gonna need about a 36-40t spur.the stock mount has a TTC (TOTAL TOOTH COUNT)of 83..so I'll need to go with mod1 conversion and aim for about a 73ish TTC so I'll have some gearing up,down options.now time for research to see if a 40t mod1 & a 40t 0.8 mod gear are same size,demensions.others have done this mod1 conversion but there's nothing out there to be found about doing it.so I'll wing it an see what works.i do know a foh spur will be needed.ill buy the mega an then vendetta body when available. This will be a longer term winter build.
Recently installed mmx6s an tp4030 in big rock to check fitment,liking it.
