- Kraton 6s
- Senton 6s
Hey guys, as some of you already noticed, I've been working on diy chassis. Inspired by the Mojave one.
I bought a 5mm 7075 plate, and work on it mostly by hand. No cnc etc. I've got some issues with the bulge for the diffs in the front and the rear. Had these 2 open, more often than I want to count.
Used the original dogbone from the back and used it for the front. Cut the original one in 2 pieces and pressed them back together. This one is now 163mm long. So that the motor is almost in the middle of the chassis. I also used the original chassis as a template to make sure that the holes fit correctly. Got a lil carried away in the end, by thrilling the holes for the side guards and thrilled some wrong.
In the end im pretty satisfied with the outcome. Haven't clean it yet. All the inner parts are clean though.
Just wanted to share.
