For awhile.. haha. Very closely monitor temps.. it will get hot quickly ...
Yes, that’s why I said “for awhile... haha” meaning that if you continuously run 8s through the 6s motor you’ll most likely explode it. But if you closely monitor your temps you’ll likely get some good use out of It still. Myself and many others have used the factory 2050kv on 8s for short term basis or just low Demand speed runs with small tires.Unless you're actually running 8s, an 8s ESC is over-built for a 6s motor. But running 6s will keep the ESC cool and it might even be a bit faster if the motor has more power than the old ESC was supplying.
Basic rule, motor determines everything. You run the voltage (or less) that your motor will handle. You can run higher, but you have to know the motor, how it was built, what RPM it's rated for, and what voltage it can handle. For example, a 4600kv is a 2S motor (most motors are rated for 50k RPM). But a castle 1406 4600 is rated for 100k RPM, so you can run 3s without expecting it to explode. It will get hot, though.
