J Mitchel
UPDATE: Upon notifying Horizon Hobby of the issue, they very quickly responded, researched, reacted and resolved the issue to more than my satisfaction. I would not hesitate to purchase another Horizon product, feeling confident that I will be well supported. With over 50 airplanes, a dozen boats and now RC cars, I feel strongly about supporting a company that provides North American based customer service agents which are knowledgeable, empathetic and empowered to make things right.
Original Post:
With tires on the way, I decided to take the Felony out for what I think is my 6th run. I still have a bit of tread left. I found a freshly paved road nearby that was still closed to traffic except one cross intersection. I powered up as usual and went back and forth 50 feet or so twice.
Then I sent it down the road and got maybe 100 feet when I had zero control. No steering. No throttle…and no brakes. Panic ran through my mind as the car continued arrow straight towards the intersection, about 150 feet ahead. Because I was not going particularly fast, the car rolled to a stop pretty quickly. Dead center of the intersection. For a 50 year old guy, I think I ran pretty quickly. I picked it up just as a car was coming towards the intersection. Still a construction zone, he was going pretty slowly, but what a panic!
The car continued to be unresponsive.
Technical troubleshooting steps I have taken and initial conclusions:
What is a reasonable request of Horizon/ARRMA? I feel I really can't trust this specific vehicle and think a physically different example would be appropriate, but I don't want to be unreasonable.
Thanks,
Jeff
Original Post:
- Rebind
- Thinking I lost bind, (no idea why that would happen) I went through the rebind and calibration steps
- This did not solve the issue. In fact, during the calibration, the steering did not function when moving the control wheel to the right or left.
- Twice during the calibration, the throttle went active in forward (but strangely, not reverse) at high speed, proving why you place the car on a stand with the wheels off the ground/table/your lap.
- At no time after rebind or calibration would the throttle or steering function.
- Servo Test
- Because the throttle went active and the motor/wheels spun up, I did not suspect an ESC issue.
- There are only two connections to the receiver, so that left the steering servo.
- I removed the steering servo from the receiver and connected it to a servo tester. I got no response from the servo tester. No left, no right, no humming. Nothing.
- I connected a brand new third party standard servo I had on hand for another project to the servo tester and confirmed that it worked.
- I connected that brand new servo to the Felony receiver and powered up.
- I had throttle, brake and the new servo turned when I turned the wheel on the controller. NOTE: my new servo hummed a bit and seemed to vibrate back and forth a tiny amount. It was a HiTec servo for a plane.
- Initial Conclusion
- The steering servo seems to have failed and done so in a way that interferes with receiver and ESC functions.
Thanks,
Jeff
