chilly81
- Fireteam
- Granite
- Typhon 3s
I wanted to get a full 4S driveshaft into my 3s without doing a major 4S upgrade with the big arms etc. Thought I had it figured out and I was darn close. 6S Infraction hubs are very similarly sized (w/r to mount points) to the 3s rear hubs surprisingly. But they are slightly longer axially and house different diameter bearings - all which works well for the 4S driveshafts.
(Jennys prices) So for $18 for two sets (4) of Infraction rear hubs (incl. fronts and bearings for spare), $10 for a set of (4) 4S hexes, and $47 for (4) 4S CVD's, you could do the rear end of two cars. $40 each - cheaper than a set of the crap Arrma HD driveshafts by themselves, and you'd have way more beef on the outboard end.
The problem that I didn't foresee is that the collar of the 4S CVD is larger diameter than the 3s stuff. So once it's all bolted up, to be able to get it to 0deg camber, that big collar interferes with the a-arm body. You'd have to grind out a pretty significant chunk of the arm for clearance. Everything else worked.
Also, should mention it would not be good for the short arm/granite style because you'd have to cut the sliders down so far. Would be OK with the typhon ones though (still have to cut them but end up as long or longer than the arrma HD cvds).
Here's what it looked like below. So bummed... thought I had something I'd be happy with. That white thing is a spacer to step down the bearing size from the 6s hub.
I know about the 3s+4s cvd approach people have been using but I don't want to put that much $ into my 3s rigs at this point, especially when the end result is going to be a hex extender on the skinny version of the axle. It's not a coincidence most of the people who have broken the HD cvd axle stubs were using hex extenders - more leverage, bending vs. shear on crap pot metal axles is not good.
Anyway..... Maybe I will try with a spare set of arms to grind a bug chunk out of them just to see how it goes.
