Senton Any ideas guys
poppajo
New Member
Senton, switched to brushless , car runs great. Insane speed in reverse, like uncontrollable speed. Very happy w the upgrade, just very curious wtf it’s so fast in reverse
Sounds like motor rotation along with throttle direction on the TX are reversed. Keep the TX channel normal (non-reversed) and if you can't reverse the direction on the ESC and the system is non-sensored, switch two of the three ESC to motor wires.
Throttle direction is reversed. Is your motor sensor less? If it is then switch two of the leads and it should work. If not callabrate the esc and switch motor rotation
