Absolutely a great upgrade. No failures since installing on my Noto 6s last summer (rear only). I run an M2C chassis and rear tower as well. I also use the stock Arrma cover, as I did not opt for the HR one since it's not sold as a set. Fit is good and I don't feel the cover was necessary.Are these a good upgrade over stock HD cases? Are they compatible with m2c parts? Any negative side effects running these?
Thanks
A lighter wallet $$$$...!! ?Any negative side effects running these?
There are de-anodizing walkthroughs here at the forum. Check posta from @joostin420 at least.Anyone know if I can use oven cleaner to remove the black anodizing on the HR parts and polish them .Want to match my m2c.
Hard to say. They’ve never responded to emails before and don’t have a listed phone number or physical address.Is Hot Racing in business anymore?
https://www.arrmaforum.com/threads/deanodizing-fun.7870/There are de-anodizing walkthroughs here at the forum. Check posta from @joostin420 at least.
I used sodium hydroxide which is inexpensive and can be purchased online. doesn't have anything other than the base itself in it.. *basically lye (pun intended)
Heres a quick link but can probably find it cheaper. https://www.amazon.com/dp/B013KMNCJU/ref=cm_sw_r_em_apa_i_qqytEbNSG95NW
This stuff looks so pretty deanodized and polished.
It shouldn't be an issueI am running the arrma metal diff cups is this going to be an issue?
