- ridgefield ct
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Kraton 4s
- Talion
- Typhon 6s
This is a 3s 5000mah spectrum reaction 2.
I also usely charge at 1 amp or under unless I'm in a big hurry.5amp charge is fast,but hard on packsIf your cells are at 2.58volts it's trash.you ran it down to low.should never see under 3.30 volts per cell
On a 5000mAh pack charging at 1c is perfectly safe and does not damage the pack its only when you exceed 1c does it start to damage the cells. 1c is mah divided by 1000. So 5 amps is 1c for a 5000mAh lipo.If your cells are at 2.58volts it's trash.you ran it down to low.should never see under 3.30 volts per cell
