1. Hard to get all of the play out and still spin freely. Try to shim best you can under the pin. Some of mine have 2 shims, some have 3.1. When moving the drive cups in and out
2. When moving the entire differential left and right in the gearbox case
Not much I can add...1. When moving the drive cups in and out
Precisely. My MT410 came with two shims per F/R diff. The instructions said "in some rare cases you might need to use both shims". I had to use both....... Thought i was doing something wrong.Adding to what HZDOS said no 2 diffs will ever require the same amount of shims. My Outcast front I have like 5 shims I think I added 1 to the center and 3 in the rear, my Kraton only has 1 shim for each diff.
