Typhon arrma 6s Typhon Center differential gear
Neon9
New Member
anybody know what center diff gear are out there? That's smaller than a 46 tooth that fit.
The size of the spur is limited by the size of the diff case. If you have the standard diff, and not the EXB diff, you can't go much lower in spur size. Robinson Racing makes great gears, and I highly recommend them over the cheaper brands.
Don't forget, with a smaller spur, you get higher speed but less torque.
