Short update!
I opened my diff, which has never been opened by myself in 3 (!) years!
How did it look?
The absence of the shimm, which is the reason the later diffs of the same series failed, is quite a discovery.
This would mean the satelite gears must have different thickness in order to fit?
To be continued!
How did it look?
- extremely difficult to open, lit did not want to come off
- the silicon oil became black, thick goo. Almost like grease, which it is definitely not
- All gears show no wear or damage. All gears have their "teeth" (WRONG, see next message)
- most remarkable: the biggest conical shaped gears do not have a shimm at all!? (wrong again, they did have the narrow shimms, not visible under the thick dirty silicon oil)
- when put back, it works again. However you feel there is fine debris in the oil, if there is a bit of sand in it
To be continued!
