I have a arrma felony and the problem I have got is when the steering snapped back into the neutral straight position one way it doesn’t quite go but straight when you make the adjustments on the controller it seems to swap side there is a slight vibration on the side that doesn’t go back straight on the left hand side of the car the steering arm seems to move up and down very slightly is this normal ? I’ve tried resetting the servo and resetting the Trim but every time it does the same it seems like it’s struggling to go one way and hasn’t got enough power to reset it all the way straight any info would be fantastic thank you
