I have a couple of 2s HRBs that I bought used from a member on here like 2 years ago and they are still rocking. I run them in my Vorza.I run HRB 5000mah batteries 6s. They work great for me but I don't have anything to compare them to. I wouldn't mind a xmas present with a brand name one though so I can see the differance
I have no issues with them, but I still want a set of really good high punch brand name ones. For when I want to beat the boys lol.I have a couple of 2s HRBs that I bought used from a member on here like 2 years ago and they are still rocking. I run them in my Vorza.
Good high punch would be Turnigy Graphene, Graphene Panthers or CNHL G+ series. Looking at this chart you see why I went with the Turnigy HD brick and the Rhinos from Hobbyking.I have no issues with them, but I still want a set of really good high punch brand name ones. For when I want to beat the boys lol.
Wow my hrbs suck. lol. Out of the rhino and panther what do you prefer?Good high punch would be Turnigy Graphene, Graphene Panthers or CNHL G+ series. Looking at this chart you see why I went with the Turnigy HD brick and the Rhinos from Hobbyking.
Your HRB's have the same cells as the Yoowoo 3s. 5000/100C graphenes I have. And also the best punch of all my Lipos so far. And lowest IR's. Charge after charge.I have a set of 3s 5000mah spektrum 100c hc that are ok, a set of 3s 6000mah Zeee 80c hc and a set of 3s 5000mah HRB graphene 100c that I recently bought from Amain.com. The hrb graphene are the better of what I have. More punch and lower ir ?
Im getting a Arrma Kraton 6s V5 And i was wondering what batteries i should get i want 2 3s batteries thanks
I have no experience with the Panthers so I cannot comment on them. The HDs over the Rhino I cannot really tell the difference to be honest. I no longer have the HD as I killed itWow my hrbs suck. lol. Out of the rhino and panther what do you prefer?
I don't really understand the chart too much, but from what I gather my hrbs are no where near what they rate them at. From the chart do you think the panther is any better than the rhino or not worth the price difference?I have no experience with the Panthers so I cannot comment on them. The HDs over the Rhino I cannot really tell the difference to be honest. I no longer have the HD as I killed it
The first item is the pack. The second is the weight of the pack. Third is the true C rate. Forth is the C index(basically the difference between the listed and true C rate). Fifth is the watts per gram. 6, 9, 12, 15, 18 & 21 are the max temp recorded during the test. 7, 10, 13, 16, 19 & 22 is the voltage maintained at 50% of discharge cycle. 8, 11, 14, 17, 20 and 23 I am not sure it says Bal so I am assuming how far out of balance the lowest cell was from the rest ?I don't really understand the chart too much, but from what I gather my hrbs are no where near what they rate them at. From the chart do you think the panther is any better than the rhino or not worth the price difference?
Okie dokie I'll prob go for the panther... xmas present to me lol.For general bashing probably not, racing or speed runs yes.
Yup. Definitely lowest internal resistance and I'm happy with my buy but the ones from Amazon are most definitely the same and cheaper.Your HRB's have the same cells as the Yoowoo 3s. 5000/100C graphenes I have. And also the best punch of all my Lipos so far. And lowest IR's. Charge after charge.
