Thanks so much going to have some fun in the snow now. ???Look at your wires... its plugged in backwards... answer is right in front of you sir... black always faces the outside of the rx.....
The new one is not working either now it wont turn on ground do you have any suggestions of a new servo maybe a savöx?Look at your wires... its plugged in backwards... answer is right in front of you sir... black always faces the outside of the rx.....
Have you looked at the servo output? Is it turning when you move the Tx wheel? Is it possibly the servo saver? With the servo removed, is the steering free moving and not binding?The new one is not working either now it wont turn on ground do you have any suggestions of a new servo maybe a savöx?
It does move when not on the ground but on ground it hardly moves. I was thinking of getting a savox SA-1230 is their anything I need to buy with it for it to work?Have you looked at the servo output? Is it turning when you move the Tx wheel? Is it possibly the servo saver? With the servo removed, is the steering free moving and not binding?
So when on the ground, the servo output does not turn? I’m asking because if your servo saver is loose then the servo swap won’t help. Just trying to point you in the right direction.It does move when not on the ground but on ground it hardly moves. I was thinking of getting a savox SA-1230 is their anything I need to buy with it for it to work?
good alternative servo if you want to save some money is the Power HD WP-23KG, using one in my Kraton and Mojave. $40 on Amazon.
I did see that one in a video do I need a servo Bracket for that? Cause mine seems kin of loose but I cant find one that will ship to switzerlandgood alternative servo if you want to save some money is the Power HD WP-23KG, using one in my Kraton and Mojave. $40 on Amazon.
How do I check if its loose? Maybe a youtube video or something else would help a lotSo when on the ground, the servo output does not turn? I’m asking because if your servo saver is loose then the servo swap won’t help. Just trying to point you in the right direction.
Turn it upside down with power on so you can see the servo saver thru the chassis hole. Now turn the wheel on the Tx and see if the servo moves. If that works, now hold one of the front wheels and try again. This should give you an idea what is giving and stopping the wheels from turning. ??How do I check if its loose? Maybe a youtube video or something else would help a lot
