Would it be better to run slightly stiffer springs?You should be halfway down the adjustment threads on shock body with preload or more depending on battery/motor combo weight. Mojave springs are soft linear k-value for plush ride during high speed rough terrain, but you still need enough rebound to naturally keep the arm’s angle split between full droop and chassis squat.
Looks like arrma has a range of them.
