Which screwholes have you used for the shock mounting, the inner or the outer ones?
The inner ones are the stock setup, the outer ones will reduce your ground clearance and soften up the suspension a bit.
Maybe the hinge pins are tight fitting? Take the shocks and links off and test for travel bindingThe I have used the the inner ones when I installed the RPM arms they felt rather stiff to move up and down of the suspension if that’s the problem
The back is sitting abit flatBut I'm pretty convinced the inner ones are about the same setup as stock. Would you mind posting a picture if how you got it set up?
The strong backlight makes it hard to see. Should have the light to your back when snapping pics ???The back is sitting abit flat
☝ What he said.The strong backlight makes it hard to see. Should have the light to your back when snapping pics ???
When I attached the arms I tested to see how freely it moved without the shocks and wasn’t as free and the stock arms is that something that will change as I drive it more over timeMaybe the hinge pins are tight fitting? Take the shocks and links off and test for travel binding
