CrHardSniper
Hi since last week my arrma vendetta is stuck in lvc mode and I don't know what to do. When I turn the esc on it flashes red with short single pulses. The battery's are fully charged
Note: This feature currently requires accessing the site using the built-in Safari browser.
Bummer. Make sure all of your trim settings on the radio or zeroed out, especially the throttle. Check all connections and make sure something hasn’t pulled loose a bit. Confirm the batteries in your remote are all good. If those simple things don’t work, unplug the servo and try again. I understand sometimes when the stock servo is going out it can do weird things to the ESC. Also, you can reset the ESC by pressing a small button down next to the power button, when the unit is on, and holding it down for five seconds or so. I’m sure others will chime with ideas. I believe your car has the spectrum smart 100 esc and not the Firma 100.Hi since last week my arrma vendetta is stuck in lvc mode and I don't know what to do. When I turn the esc on it flashes red with short single pulses. The battery's are fully charged
