Okay, i've got some data here that is genuinely -- and I mean genuinely -- confusing me. I did lots of testing yesterday to see what happens to the pack. Rather than try to post pictures, i've layed everything out in a table format based on the order I did these tests. As suggested, i did some charges and discharges, followed by a balance before repeating. And i tried charging to various cell voltages.
What's really odd here, is that the charger will perfectly balance charge the lipo to 4.0 and 4.1v per cell, but charging to 4.2v per cell triggers this..... anomaly.
To make sure it wasn't the charger or this channel, i charged this lipo's "sister" pack (same specs, bought at same time) on the same charger channel immediately after. The sister pack was fully balance charged in 40 minutes, with no appreciable temp increase on the packs. I then decided to charge to 4.15v per cell on the problem lipo and more closely watch the charger to see what was happening. This is the abbreviated timeline of the major events:
Unfortunately i don't have much more second for second granularity as I simply didn't have time or will power to stand by the charger in the 90f garage. The charging was going 100% normal when charging at 6.6amps (1c) everytime I checked, cells were aligned in voltage. But at some point the charger started ramping down from the 6.6amp charge and hit the "final balance" portion of the charge, the third cell voltage began dipping and the other two went up. Within a minute, the third cell was noticeably warm and then around 2 or 3 minutes it was 110f,
but only on one side. I took this to mean that, for whatever reason, the third cell was being massively drained while the other two were being quickly charged--or in other words, it seemed like all of the third cell was being pumped to the other two. i stopped the charge, and restarted it at 4.17v per cell final to see if I could trigger it to restart. However, nothing changed, and cell 3 votlage dropped below 4.100 before i killed the test.
That would make me think this is a charger issue, but it has absolutely no issues balancing any of my other lipos, including this lipo's sister pack, just fine.
Again, i'm honestly stumped. I might try this again and take a video of the charger screen to see if I can catch any more minutia. Could this be an internal short of the lipo? Your brain power is appreciated.
