ball joint fix
Discussion in 'Nero, Big Rock & Fazon' started by tunepoet, Jun 26, 2018.
  1. tunepoet
    tunepoet Member
    May 28, 2018
    11
    Arrma RC's:
    Nero
    Hello;
    This may be old hat for the experienced, but are their any tricks to getting a ball joint to twist onto a turnbuckle? Hot water? Something to stretch the nylon? etc. Your advice is highly regarded.
    Blessings,
    Damon †
  2. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    374
    115
    Use a spare turnbuckle to thread it using a drill. You have to flip the turnbuckle for threaded ends as they are threaded in opposing directions. Hold the ball end in pliers, then use the drill to let you thread the turnbuckle in straight. Gives you more control and isn't as annoying.
    slick2500 likes this.
  3. slick2500
    slick2500 Well-Known Member
    Aug 21, 2017
    1,442
    530
    Rapid City, SD
    Arrma RC's:
    Outcast
    A little lube on the thread helps from my understanding.
  4. olds97_lss
    Dec 14, 2016
    374
    115
    Yeah, a little bar soap or wax works too. Then it doesn't collect dirt when out bashing.
  5. slick2500
    Aug 21, 2017
    1,442
    530
    Rapid City, SD
    Arrma RC's:
    Outcast
    I swear I saw a guy use chapstick once.
  6. 2fast4u
    2fast4u Well-Known Member
    Sep 12, 2017
    87
    42
    Delaware, Ohio
    Arrma RC's:
    Kraton
    I use silicone spray with good results. It may not apply here threading into plastic but I had an experience once when I maintained a fleet of class 8 trucks where heavy lube (gear oil) on the threads of a new pinion with a new nut hydraulicly locked before the nut was even clear on the shaft using a 1350 ft.lb. air impact. Cleaned the pinion and nut with brake cleaner applied the proper thin lube (which I just didn't feel like going over and getting in the first place) and then spun it on by hand to the nylon ring and finished just fine with the impact.
  7. tunepoet
    tunepoet Member
    May 28, 2018
    11
    Arrma RC's:
    Nero
    Thanks... Ok, some sort of lubricant. The drill is a good idea but the turnbuckle is already connected on the wheel side, and I don't have a spare turnbuckle to experiment with. appreciated! †
  8. slick2500
    Aug 21, 2017
    1,442
    530
    Rapid City, SD
    Arrma RC's:
    Outcast
    If you are careful you can stick the rod end in the drill.
  9. tunepoet
    tunepoet Member
    May 28, 2018
    11
    Arrma RC's:
    Nero
    thanks, I will think about it but not sure I have the confidence to give that a shot, but I will have a look at the drill...
  10. olds97_lss
    Dec 14, 2016
    374
    115
    Well, you could chuck the turnbuckle in the drill and remove it from the rodend on the truck, then flip the turnbuckle, thread the rod end that hasn't been threaded yet, then thread the other end while still on the truck.
    2fast4u likes this.
  11. tunepoet
    tunepoet Member
    May 28, 2018
    11
    Arrma RC's:
    Nero
    Got it done thanks (kind of relieved). Used some soap combined with excessive force. my palms have new creases in them.
    blessings †
  • Welcome to Arrma Forum
  • Disclaimer
