is that the standard or the speed? i haven't paid much attention to the pinion tooth counts.
That is what Venom came back with for the specs? If so, you are pulling too many amps from the batteries and that's why they are getting really hot. That would have been bad if it was a lipo with those specs lol.Venom NiMH 8.4V 5000mah:
The internal impedance at 1000Hz is 5 mΩ(Max). Max discharge is 30A.
Yeah you are just going to kill those batteries if you keep running them in the Kraton. That missing bolt isn't going to make the batteries run hot. As I said before, batteries get hot when they are under powered for the application, ie they cannot provide enough amperage to power the vehicle. There is no way to magically fix this, even if the hobby shop guy got 130a out of them these escs can still pull 400+ amps in bursts and that 130a doesn't even touch the nominal load of the esc which is 150a.Venom NiMH 8.4V 5000mah:
