SaltyLocal
Hello,
I recently purchased my boy an Arrma Big Rock V3 and I've yet to open the box. His 6th Birthday is coming up and I'd like to get it prepared for him once he opens the box (as I'm sure he'll run outside and test it out). I've watched some YT videos and I'm unsure what screws (V1 vs V2 vs V3 models) should be lock-tyte, tightened/loosened, and/or anything needing white greased or oiled (shocks?). Is it recommended to install the included shock caps (not sure if that's what their called) for added durability/clearance? Also, will I need to calibrate or adjust anything prior to him taking it out for a bash? I've also purchased both a 2s and 3s battery; thinking the 2s will allow him to get use to driving it prior to going out and loosing control of it. Are the 2s OK in it? I'm also thinking I'd turn down the power setting to 50% ?? I also had some 3D prints made to help protect the roof, hood and rear corners (general pics attached). My question is, if I use a hole reamer to add these 3d prints to the body, will this make the body itself weaker and allow it to crack a lot easier?
Finally, in regards to immediate upgrades; are motor mounts from M2C or Hot Racing worth the added cost? Do the Big Rock V3 shocks, ball joints, servo, and spur gear need replaced ASAP? Any other recommendations would greatly be appreciated. Sorry for all the questions.
