Mike-NLD
Guys,
Was running my Typhon today..
At some point.. At about 50mph.. Buggy started grinding gears.. Immediately let the throttle go in neutral, and let the buggy come to a rolling stop.. Then checked it out..
Quick find.. Pinion had a wobble in it.. Blew the front (pinion-side) motor bearing..
To get that confirmed.. I wanted to take of the pinion and open up the motor..
And there is my 2nd problem.. Pinion wont come of! After heating, grub screw came out no problem.. But the pinion is somehow stuck on the motor shaft.. It wont budge.. Nothing at all.. Any tips?
So at this point.. I need to fit a new bearing..
And finally.. These questions:
A: is my motor save-able..
B: if yes, are these motor bearings special quality?
C: if yes, where to get them?
