ManiacMac!
I need some new bearings for my Noto, but I don’t wanna spend $30 on Fast Eddy bearings. Do y’all got any recommendations for a decent brand that sells a full set for $20-$25?
do they come with enough grease in them or did you need to add some?Got these in my Kraton 6s. $23.96
https://www.ebay.com/itm/1539033032...q7FPNHENTvG&var=&widget_ver=artemis&media=SMS
They were good.Has anyone ever tried these?
https://jimsbearings.com/products/arrma-mojave-6s-blx-exb?_pos=1&_sid=43580f942&_ss=r
I've used about everything in the book. Honestly you can just caliper your bearing and get a pack of even the cheapest possible ones on amazon work just fine. If I buy a brand its TRB RC. But in all honesty bearings are replaceable and now days the cheap ones on amazon are as good and expensive ones. Kinda like servos now, you don't need a $80 savox anymore. $20 to $30 servos are totally fine.
Well heck that is unlucky , that exact one that i linked i currently have 7 of and have had a total of 13 to date, 0 issues a couple are years old.I have terrible luck with servos, the $20 ones seem to last forever in my 1/10 scale rigs but those $30-40 servos only seem to last 2-3 packs before they go full potato and just start wigging out.
Were the potato ones EcoBoosts, ive not heard of many dying and I've had 100% luck with 13 now.
I gotcha so not the nice fully aluminum, steel geared, amazing JX ecoboosts that i posted hahahaha. I thought you meant you had JX's go out, that would be as rare as a $200 MKS going out, and I got 4 of those. That would be a bad day if I had a MKS go out.I bought some random bearings from them once worst bearings I've ever seen the gaps between the seals were so big in some that you could see through the bearing.
Yeah I have like 6 or 7 of the 20kg DS3225MG servos some are like 5 years old now, the blue DS3235sg servos are the ones that keep dying so I gave up on them.
I’m surprised to hear that, I’ve never had an issue with them. I buy them because they’re cheap and my bearings constantly get wet. I blow them out and oil them, but I do end up having to replace them fairly often.I bought some random bearings from them once worst bearings I've ever seen the gaps between the seals were so big in some that you could see through the bearing.
Its ok hahah, it is super common i see @slick2500 come in and say something is trash for him that everyone else has good luck with... hahahaI’m surprised to hear that, I’ve never had an issue with them. I buy them because they’re cheap and my bearings constantly get wet. I blow them out and oil them, but I do end up having to replace them fairly often.
Yeah esp if you get bearings wet, use the absolutely cheapest you can get as water ruins them all fast and the same haha.I’m surprised to hear that, I’ve never had an issue with them. I buy them because they’re cheap and my bearings constantly get wet. I blow them out and oil them, but I do end up having to replace them fairly often.
I had one of those JX Ecoboosts die on me after like 3 packs too.I gotcha so not the nice fully aluminum, steel geared, amazing JX ecoboosts that i posted hahahaha. I thought you meant you had JX's go out, that would be as rare as a $200 MKS going out, and I got 4 of those. That would be a bad day if I had a MKS go out.
Sorry slick for all the bad luck, just in general... You at least say it like a gentlemen, "its bad for me" Not just its BAD!!
This was like 5 years ago so maybe they changed to a better supplier since then idk.I’m surprised to hear that, I’ve never had an issue with them. I buy them because they’re cheap and my bearings constantly get wet. I blow them out and oil them, but I do end up having to replace them fairly often.
haha again not surprised... But i can 100% assure you that your results are negligible here, those are amazing servos. I feel like if you were a PC tech youd run into dead mobo's and PSU all the time. I almost never did back in those days. But it is super common to get a bad PSU, esp 20 years ago.I had one of those JX Ecoboosts die on me after like 3 packs too.
Yup online reviews for ya, forum or not, its only really reported when its bad... IRL i don't know anyone that has had bad luck with cheap amazon bearings or with those winter bearings. Just people online ill never see or meet "statistics" basically in my book.I've seen a few others having the same issue with some of the cheap Amazon bearing kits too.
