I am running newer 6s 5000 MAh Pulse batteries that were 65c in a Kraton 1/8 scale. My Kraton has more recently started going into low voltage cutoff or limp mode. The manual only shows you how to set your end points, is there a way to also remove the low voltage cutoff? Is there a separate manual that I can't seem to find?
Thank you,
Sean
Thank you,
Sean
