Big Rock Blx esc to 30mm fan
palmryde
  1. BigRock 4x4
  2. Granite
  3. Typhon 6s
Anyone make a fan adapter to run a 30 mm fan? Not a whole lot of selections for 25mm
Might as well find or make a 35mm or 40mm ESC fan adapter at this point. Space permitting. Having it raised higher for clearance if needed. You can always make your own adapter. Aluminum Fans are usually more durable.
Keep the fans from getting full of debris/ cut grass etc. or from getting wet. Or most any fan will die fast.
would a 2 pin jst plug into the stock esc?
It should fit. :unsure:
Being mindful of the correct polarity. Reversing by accident should not cause any issue however with fans, if you make a mistake the fan just won't work. But as a matter of practice and habit , always observe polarity first.
