Big Rock Body protection
Gearhead04
  1. BigRock 4x4
Any good advice on what to get for body protection for the Big Rock?
Are you located in the States?
I can 3D print some for you.. They are simple enough.
Just PM me,
and I'll let you know what I have on hand.
Think the Maxx roof skid will work with the BR.
Works great, made a template, drilled the holes, done. The wing resolves the rear rear body abrasion issue.
The Proline Lid Skid Body Protectors aren’t the cheapest but they work well and come with nuts and screws. A rear wing is a must to protect the back of the body or it will be demolished before you even notice wear any where else. Here’s our skatepark body outfitted with lid skids. The rear protectors aren’t really necessary once you add the wing. I added the wing after the protectors because even with the protectors the flex was punching the body posts through the shell. If you get the wing I recommend the special screws that go in the holes which have hex holes both ends so you can replace them when they wear down. Our first wing got scraped down quickly without those screws.
