He is showing you that it can handle 6sWhat does this mean
What does this mean
Do you have to use throttle control to run 6s
If you are not used to controlling the throttle, you really need to stick to 4S on these trucks. 6s is a huge amount of power, and you really spend most of your time at about half to two-thirds throttle. You really only use Full Throttle for very short punches to flip in the air or get an extra burst of speed right before a jump.Do you have to use throttle control to run 6s
Like do u have to ease into the throttle when accelerating
So basically if u don't ease into the throttle your driveline will not last on 6s
Once again, the Driveline can handle 6s fine. But if you don't control the throttle with your trigger finger, you will crash a lot, and crash at very high speeds. High speed crashes will break the truck.So basically if u don't ease into the throttle your driveline will not last on 6s
