Typhon Cant reassemble motor
Captain Flint
  1. Typhon 3s
Finally got the bearings replacement for the motor but now it seems to sit perfectly bit i cant close it back together.
(Second picture is without the bearing, maybe something is wrong that i cant see)
make sure the bearring is pressed enough on the rotor, maybe there s a little stump where you need to press it a little harder to get it over
Cant push it more than this
Look at the shaft... the old bearing race is still on it... it needs to be removed
There should never be a reason to hammer or press the end of the can on...
thought it was part of it.... the old bearing just shattered inside so i never got to see it without it... thanks :)
It's common for them to come apart... always remember there is always an inner and outer race to every ball bearing...
Keep an eye on that front bearing, alot of crap has the potential to jam in there and waste the bearing.. I check and service mine every 6 packs
Closed perfectly and runs smooth, gonna change all the bearings while im at it and go back to bashing
Excellent buddy... glad you got It sorted... (y)
