Thanks I always wanted a tp but never understand how they work with esc’s too many options lolI just got the 1721...imo your gonna be better with the 2028...just because it's a less radical motor to control an much less issues to run into to
Ya wanna save some $$,I'd go with tp5660 or tp5670...1100-1500kv..
TP motors work fine with Castle ESCs. Take your pick of any 4-pole TP motor without having to worry about potential sync issues. If, however, you intend to pick up one of the large can 6-pole motors, conventional wisdom and experience tells us to stay under 1500KV.Thanks I always wanted a tp but never understand how they work with esc’s too many options lol
The 1721 is a really good motor imho. It's quite versatile in terms of what voltages it can perform well at, it has a stainless steel encased rotor which really does a lot for a motor's durability and longevity. After talking with @vwturbowolf, you can view the 1721 and the TP 4080SVM 2400KV as close to identical as two motors as dissimilar as the two are can get in terms of RPM, current draw and Vmax. Performance in the same car with the same batteries was within 1mph IIRC. That's the last info on those two motors that I got anyways. The 1721 is a supremely smooth and quiet motor that produces very little mechanical running noise. The rotor is very "loose" in the magnetic field so it doesn't "clunk" into position between the the three magnetic fields like a lot of other motors do. It's very pleasant sounding and, if you run at 2-3am like I do, it's kinda nice because you don't feel like you're likely to bother any neighbors if you're running in or near residential areas. Granted, that's a pretty specific bonus feature that probably doesn't factor in for a lot of people. Most people speed run at a slightly more normal time of day. But I thought it's worth mentioning.The 1721 seems to be a very popular speed run motor. I think quite a few guys here use it.
@Diem Turner
I got this motor as a novice in the speed run game and I can say its a learning curve and I'm still coming around the turn lol. It is very powerfull and worth the money in my opinion. Very smooth and consistent. Also be aware that the new 2028 1700kv motor was release recently, so check that out so you don't have buyers remorse if you didn't know about it before haha. Here is a suggestion...buy both TP and the 1721 and give us your thoughts lol.I was looking for a motor for my v2 lim I’m purchasing I’m running an xlx2 and I ran into this motor it says 2400kv but is 46 mm and 101 length comes with warnings who knows about it and it is good for speed running vs 2028 1100kv one?
Awesome so I can run it with xlx2 in other words lol and not that size matters lmao it’s a big van motor at 100mm that’s the size of the 1717 1650 kv correct .TP motors work fine with Castle ESCs. Take your pick of any 4-pole TP motor without having to worry about potential sync issues. If, however, you intend to pick up one of the large can 6-pole motors, conventional wisdom and experience tells us to stay under 1500KV.
Lmao I wish I was going for the 2028 xlx2 and then I ran across that motor so 2028 won’t overload the esc ?I got this motor as a novice in the speed run game and I can say it’s a learning curve and I'm still coming around the turn lol. It is very powerfull and worth the money in my opinion. Very smooth and consistent. Also be aware that the new 2028 1700kv motor was release recently, so check that out so you don't have buyers remorse if you didn't know about it before haha. Here is a suggestion...buy both TP and the 1721 and give us your thoughts lol.
That would be a TP5670 then, correct? That's a bit bigger than the 1717. It clocks in at 49x88mm and the 5670 is 56x102mm. That was a cleverly placed typo btw. The misdirection was real. I was trying to work out which RC van you pulled a big motor from for two or three seconds before realizing that it was supposed to say big CAN motor.Awesome so I can run it with xlx2 in other words lol and not that size matters lmao it’s a big van motor at 100mm that’s the size of the 1717 1650 kv correct .
Lmao I’m working and trying to solve my rc problems at the same timeThat would be a TP5670 then, correct? That's a bit bigger than the 1717. It clocks in at 49x88mm and the 5670 is 56x102mm. That was a cleverly placed typo btw. The misdirection was real. I was trying to work out which RC van you pulled a big motor from for two or three seconds before realizing that it was supposed to say big CAN motor.
That's the way to make good use of time at work.Lmao I’m working and trying to solve my rc problems at the same time
