- Felony
- Fireteam
- Infraction
- Limitless
- Kraton 8S
- Kraton EXB
- Kraton 4s
- Mojave EXB
- Notorious
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 3s
- Typhon 6s
- Typhon TLR
Are you sure you can't reset it without a pc? I know you can reflash the firmware with the mobile app for sure. Btw you should go to the actual clear data log button and hit it anyway.There is an apple app for the phone which I read is only recommended for field use not resetting the esc. I used to use umbutu back in the day but don't really feel like dealing with all that to use esc adapter. I've uninstalled and reinstalled app like 3 times. That deletes data logs. reset b link with reset pin. The fact you can't reset an esc without a computer is retarded to me!
Tbh, with castle esc's I've run into the same problem numerous times and it always happens randomly and is definitely a bug. My esc will stop working until i clear the data log. The data log won't even be full, at least it won't report as full. It still won't work until I clear it though.
Try reflashing the firmware too!!
Btw what is the light on the esc doing?
