NorwegianBasher
- Kraton 6s
- Kraton EXB
Hi
According to Castle the Mamba Monster X 8S BEC specs are: "Powerful Integrated 8A Peak Adjustable BEC (5.25V-8.0V)"
However, a powerful 1/5 scale servo will require more than 8A peak under heavy/peak load. For example, the servo I am considering to combine with the MM8S is the PowerHD WH65. It`s rated at 10A stall current at 6v and a whooping [email protected]. I want to run the servo at 8v driving non-stop on bumpy grass with a strong servo saver spring.
I did see this exact combination in a youtube video in a K8S. No issues in the first 15min test drive on grass, but I suspect I will be pushing the servo/BEC a bit harder.
On a side note, the AGF A280BHMW is rated at 11-13A(depending on the spec sheet) @8,4V. In general it seems the powerful 1/5 scale servos can peak far beyond the rated 8A of the MMX 8S.
Just wanted to check with you guys if anyone have experienced issues. I don't want to try the combo and risk any issues with the ESC or not getting good power out of the servo. Currently running Hobbywing Max ESC, but I would like some of the Castle features. Would be nice to avoid the heavier and more expensive XLX2 with 20A peak BEC if not needed. Not interested in running an external BEC and quite certain I am happy with the power of the MMX 8S.
