- Mojave
Just buy a new center diff on Jenny's RC. Alternatively buy a new alu center diff with all the parts.
You might want to invest in a dusty cover, would have prevented this.
https://jennysrc.com/collections/ar...fferential-diff-50t-spur-gear-kraton-ar106048
Thanks for that heads-up!
By the way, do you know if there's a specific aluminum cup that can be used for LSD's, do the Arrma and Hot Racing cups contain spider gears, sun gears and LSD plates properly? This diff thing is highly confusing for an autistic n00b. Can LSD plates be used in all aluminum cups or is the composite cup needed? I've seen the exploded view and the LSD plates must take more space than the 2 shims in BLX diffs under the sun gears? Anyway, don't mean to assault you with these questions but a n00b adrift in a sea of Arrma diff details is a bit of a plight. Thanks a lot if you have a spare minute though, cheers.
I feel bad for asking two people the same question but are these Arrma aluminum cases compatible wit LSD components, is there enough room in the case? Just looking at pictures the aluminum case looks more squat than the composite cases but it's so hard to tell being clueless like I am and havin no reference. Thanks a lot if you get a minute, cheers.I use this Arrma option part. Others use Hot Racing.
METAL DIFF CASE (ARA220050) | ARRMA - Designed Fast, Designed Tough (arrma-rc.com)
200k CST or 500k CST. whatever you can find. I prefer 500k/center in my Noto and Kraton 6s. Running larger wheels/tires gets 500k IMHO.
