I'm doing diff maintenance and I already got the front and rear diff filled with new fluid and greased the ring gear with some Red n Tacky. Do you guys put any grease on the center ring gear that meshes with the motor?
Nope. Will fill with grime and turn into grinding paste. Some guys use a dry lube - I don't.I'm doing diff maintenance and I already got the front and rear diff filled with new fluid and greased the ring gear with some Red n Tacky. Do you guys put any grease on the center ring gear that meshes with the motor?
