I have two batteries for my blx 4x4 Kraton 4s, a 3s and 4s battery. The 4s says us 2c charge rate, and the 3s is 3c. The charger says 1-4a charge rates but no c rates. I've been using 3a for the 3s and 2a for the 4s. Is this safe?
You have to calculate the Amps yourself. It makes no difference how many cells (3s vs 4s) the battery has.I have two batteries for my blx 4x4 Kraton 4s, a 3s and 4s battery. The 4s says us 2c charge rate, and the 3s is 3c. The charger says 1-4a charge rates but no c rates. I've been using 3a for the 3s and 2a for the 4s. Is this safe?
Depends on the capacity of your Lipos. You chose a low current, so you probably charged with even less than 1C. Everything should be fine.So I've been doing this charging incorrectly for about a year now and the batteriesare still working, should I get new batteries, or should 8 be OK if I charge at 1c from now on?
Depending on the battery size, they should be fine. charging at less then 1c will not hurt the lipo.So I've been doing this charging incorrectly for about a year now and the batteriesare still working, should I get new batteries, or should 8 be OK if I charge at 1c from now on?
The 3s is 5000mah and the 4s is 52000mah
You can probably just put in 5A for both packs and the charger will try to do its best.So should I keep it at 1a for now or get a better charger?
If you have the budget, a good charger is about the closest thing to an 'investment' in this hobby. A good, powerful, multichannel charger will be something you will use for years, for all your RC needs. Keep that 25w per cell rule in mind, though. Some multi channel chargers only list total wattage, and if you have 2 or 4 4s or 6s packs, that 25w per cell quickly climbs to be a very large number...So should I keep it at 1a for now or get a better charger?
no.Does arrma do nitro?
Ditch the wall charger they are not that great to be honest most charge at like 0.1amps. The last one I had took 9 hours to charge the 900mah battery.I have 3300 mah battery and have charged it for 6 hours and it still is not showing on the part that plugs into the outlet that it is ready should I be concerned?
