Fpv questions
Anthony jaques
Delta colorado
  1. Fireteam
  2. Vendetta
Hello all I'm interested in getting an affordable fpv been looking at the dumborc 4.3 set its bout 70 but I'm curious if anyone else has tried the camera is 5v max so that a negative been looking at the spotter v2 camera but don't want to buy the kit and be replacing stuff that needs to be better anybody try this or have a decent suggestion for around 70 thank you
With cameras you sort of get what you pay for. Cheap cameras and FPV setups tend to have less resolution and shorter range. If you bashing in the back yard, this might be fine. However, if you want to run it around the block you're going to need to invest some time and money in to it.
You might check out Chadd Rains. He has a bunch of FPV stuff.
https://www.youtube.com/@ChaddRainsFPV
As a side note, I found your post a bit hard to read. It all blurs together with too many thoughts in one place. If you can break it up in concise sentences and questions it would help us old guys.
